UnitiQute Clock - 12 vs. 24 Hour
Posted by: Lawgrass on 20 April 2014
Hello all,
I just purchased a new UnitiQute (version 1 new in the box), and absolutely love it.  I can't say enough good things about the performance, features, and ease of use.  I had been hesitant to make the jump to streaming audio, and it took this product to make me feel comfortable finally making the transition.
The unit was shipped with version 3.0 software, and with the advice of Naim customer support, I just upgraded to v3.9 first, and then v3.22. I experienced no problems and upgrade process was painless.  I used a Gigaware USB to Serial adapter and had no issues with that device on Windows Vista.
One of the new features supported by the latest software (actually I think it was available starting with v3.9) is the Clock and Alarm.  My question is regarding the clock display.  It seems to default to a 24 hour clock format. Is there any way to set it to a 12 hour format?
Thanks in advance for any help you can provide.
Posted on: 21 April 2014 by Gavin B
Doesn't look to be an option in the Settings.
Posted on: 21 April 2014 by DelR
Thew, I though one was going to sound better than the other.
Posted on: 30 April 2014 by Lawgrass
Just heard back from Naim  and the Unitiqute currently only supports the 24 hour clock.
