Yba pre 400 preamp and Naim nd5xs – a match made in heaven.
Posted by: SUPEROX on 24 April 2014
Hello Guys,
I have finally found the source that has tamed my YBA PRE400 and given a "body" into the music. I still retained the transparency and micro-detail that YBA is known and with the known midrange/toe-tapping sound Naim is known for, it has definitely showed through my system.
The only problem is that when I use the BNC input with a bnc adapter (supplied) using a digital coaxial, I get a clicking sound but with the USB there is no problem (infact Miles Davis sounds alive....now).
Could this clicking be a cause of impedance mismatch ? Any recommendation for a good digital coaxial ? I had been looking at audioquest BNC cable sold on ebay.
My first foray into NAIN is a success indeed so now I can have a good foundation for a better upgrade! ![]()
I look forward for your suggestion.
MUSIC:
I LOVE JAZZ AND CLASSICAL. Mahler, Schubert, Miles Davis.
SYSTEM:
YBA PRE 400 PREAMP
AUDIO RESEARCH CD3 MK2
ATC SCM 50A ACTIVE SPEAKER
CABLES:
ACOUSTIC ZEN MATRIX REFERENCE 2 (preamp-active speaker)
Normal belden cable RCA (NAIM ND5XS -YBA PREAMP)
