SSDP advertisement interval on Synology
Posted by: Professor Fink on 25 April 2014
Hi everyone
Has anyone perfected a setting for this value? I'm using the native Mediaserver software on a Synology DS214 play with a wired ethernet connection to a UnitiQute 2.
This value is having some effect on my connection dropping...
1. Set to default 918, I get a dropped connection after after about 1 or two tracks, then all is well as long as I keep playing, any length of time not paying from the Synology and the process repeats dropping after one or two tracks
2. Set to 180 and it drops the connection frequently
3. Set to 1500 and it drops the connection more frequently
Anyone had this issue and resolved it?
Thanks in anticipation.
Simon
