n-Stream issues when compatibility mode is disabled
Posted by: Doppy1977 on 12 May 2014
Hi All,
I've seen a few posts on this subject, many of which are inconclusive and after several days of trying different things I believe I have the answer.
I recently bought a QNAP HS-210 and Naim SuperUniti. The QNAP and Naim connect to my Sky Broadband Router/Switch, and my iPhone and iPad are running over the wireless network with n-Stream.
I found that Compatibility mode would work consistently on n-Stream, but it's basic and I wanted the full features that you get with Compatibility mode disabled. When I disabled, however, it would work only intermittently, and slowly.
I thought that it was due to the UPnP Server, so tried Twonky and MimimServer, same issue with both.
I then saw a post saying that a similar issue was caused by the Broadband router/switch. So I thought back to my Network Engineering days, and looked at the configuration on my router.
My Wireless channel ID was default/auto. I remember that overlapping channel ID's cause Wireless performance issues. So set it to use channel 6 - Channels 1, 6, 11 are the best Wireless channels to avoid overlap.
After everything rediscovered the Wireless Network on channel 6 (this happens automatically) I can now use n-Stream without the Compatibility mode without issues.
No need to spend days trying new UPnP servers, or to replace your router, just change the wireless channel, as your neighbours are probably running default channel 1 also!
Hope this helps others, Carl
