Unitiserve expectations
Posted by: Kage on 13 May 2014
After ripping all my CD's via XLD to my Synology NAS in wav format, I've been told a US would improve things further-better rips, storage, tagging, playback etc.
i must admit, my sound is a touch 'hard' so an improvement in this area to a slightly softer, natural presentation would be welcome.
i have a demo lined up next week to hear the benefits of attaching a US to my ND5XS/XP5XS+Lavardin IT. Prior to hearing the effects for myself, has anyone heard the difference a US makes to a ND5XS? I'm certainly looking forward to hearing it all for myself next week. I'm not looking forward to potentially re-ripping my whole CD collection!
Many thanks
Sorry, can't help.
You still knee deep in Basmati?!
Chris
> has anyone heard the difference a US makes to a ND5XS? <
No, but I have heard the differences it makes to a Naim DAC, an M-DAC, a UnitiLite, a UnitiQute and a Hugo DAC, compared to a laptop Windows computer source. If you're looking for a softer, more natural presentation, it is the right way to go if you want to stay within Naim. Note that addition of a third-party linear power supply to the US increases these benefits.
Jan
Thanks Jan. That's positive.
Hi Jan, can you clarify how the ULite & UQute were connected to the UServe? I'm assuming it was dig. out to the DACs you mentioned, but the streamers..?
I have the 2TB HD U-Serve connected to the ND5 via Ethernet but I also have a HiLine in my system, see profile for details.
In comparison to streaming from a NAS, in my case a WD My Book Live, the sound is not sharp but it is cleaner and more open. Now it's difficult to give an accurate summation because the differences are very slite. Also note that my NAS is a very basic one as it is soley used for back up duties and was never intended to substitute the U-Serve in any conceivable way.
"slightly softer natural presentation", I don't know!
You also have an XP5 on your ND5, could that be part of the problem? I don't know as I have not heard one on mine. But the HiLine has certainly cleaned things up on my system which I like, but others here say they found it 'hard' in their system.
So, that has not helped you at all has it? Sorry, but I don't think you will really know until you hear it.
Jason.
Digital out from the US to the digital in of the Qute and the Lite. Similar observations when comparing a NAS vs the US into the streamers, via UPnP.
Kage,
Before dropping cash on a US, have you experimented with using a network switch to isolate your audio traffic from other network traffic ? Also, have you tried different ethernet cables ? I have no experience with exotic ethernet cables, but others here have reported good results.
Jan
you'll probably have to re rip simply because wav tagging is hard so various software developers handle it differently. i.e. the server probably won't see the was ripped by XLD.
If you honestly believe wav ripped by XLD will sound different to wav ripped by Userve, your money would be better spent with a doctor.
Jason.
Hi Jason
The XP5 XS took the edge off the ND5 XS. It also seemed to reduce 'noise'.
I have also fitted an aftermarket network cable. It's by Audioquest and after comparing to my standard Cat5, it certainly reduced a bit of sharpness. However, unless you try it you probably wouldn't notice any issues beforehand.
Many thanks
Garyi
I'll believe it when I hear it! Otherwise, yes it sounds crazy.
Jason.
Hi Jason
Many thanks
Thats interesting kage.
Hmmm. that you hear your ND5 without any "noise", if you heard mine you will probably take one step back
I think I am with Gary, at the moment, and suggest you try other less expensive tests first...although you do say you will demo the U-Serve anyway. So please report back once you have as I would be interested in your conclusions and how it sits with the XP5.
Jason.
Thanks for the details Jan-Erik.
