We nas drive
Posted by: rupert on 15 May 2014
Hi can anybody give advise my 2tb nas drive keeps doubling the music and titles,It is a wd one,two years old otherwise works fine,regards
Posted on: 15 May 2014 by garyi
You sure its the nas, have you tried nstream in compatibility mode?
Posted on: 15 May 2014 by hafler3o
https://forums.naimaudio.com/topic/nas-drive-1
it seems you are posting the same question twice over so maybe it is you who are responsible
Posted on: 16 May 2014 by hafler3o
How are you viewing the files on the drive, when I installed mediaMonkey on a portable PC at home it reported there was two of everything?! Logging in to the WD sw from the SmartWare installed on another drive showed single WAV entries (as expected). So how and where are you viewing the files and what's your sw versions?
Posted on: 16 May 2014 by rupert
Hi thank you for advise I think the fault lies in n remote if I put it in shuffle it plays titles singly, Tried rebooting remote no difference I'm going to get my stream x upgrade to iPad  with up grades. best regards
