US SSD not reading disk problem solved!
Posted by: Audioneophyte on 21 May 2014
To all,
there have been several posts regarding Unitiy serve's being unable to read some CD's for unknown reasons.
So I can a test:
6 Previously un readable CD's (which I own)
then scrounged up the same CD's just different original versions.
So same CD just a different one which could be also bought at store/online etc.
On 5 out of 6 disks the alternate version worked successfully.
So I believe it has something to do with the specific CD pressing and not the US.
So if your disk is not being recognized then acquire a different version of it and give it a go.
