UnitiQute Reset All Settings problem
Posted by: Twisterbar on 22 May 2014
I was having problems connecting to the Synology Server and decided to use the "reset all settings" parameter in the Factory Settings Menu.  Now all I get is a display saying "Analogue" and the unit will not respond to any of the remote command and the Ipad won't detect it. I am way worse off than when I started and don't know how to recover. Any ideas or help would be appreciated.
Posted on: 22 May 2014 by hungryhalibut
It sounds as though it is no longer connected to the network. Try turning it off, rebooting your router and then turning it on again. Follow the quick start guide to get it all linked to the network.
Posted on: 23 May 2014 by Gavin B
HH is correct; you'll have to re-add it to your network.
Posted on: 26 May 2014 by Damon
I have this sort of problem with depressing frequency. When powering the UQ on and off does not work, I unplug the unit from the wall for a minute or two; that will often make the difference.
You may also need to reset the remote, but try the unplugging test first.
Posted on: 26 May 2014 by hungryhalibut
It sounds as though you need to fix the IP address.
Posted on: 27 May 2014 by Damon
whom do you mean by 'you'?
Posted on: 01 June 2014 by Twisterbar
Thanks everybody. got it up and running again by rebooting and resetting the remote.
