HDX will not start
Posted by: Wackymatt on 24 May 2014
I have a poorly HDX. After powering down normally using the standby button on the front(something I rarely do as I always leave this on), several days later I switch on the system and it fails to start.
Rather strangely the front panel will stay on 'please wait' for ages, then the home screen will appear for a split second then return to the the 'please wait' screen. This happens in an endless loop.
The system is connected to a network. There seems to be two IP addresses assigned, I forced the HDX to re-register different IP-addresses by changing the DHCP server ip address range to see if there was some strange conflict. This has not helped. I can ping both IP addresses from a PC
I've checked the bios settings, this is set to Naim Default. I had an issue before where the system failed to start due to a booting problem caused by the fact the hard disk wasn't set up as the primary boot device. I have no idea why this setting got changed.
I've tried the desktop client on a PC, this cannot find my HDX, the web server also seems to be out of action.
Does anyone have any tips on what to try next? I'm running firmware version 1.7a. Unplugging the network cable doesnt help either.
