Songbook for naim
Posted by: lhau on 24 February 2011
Anyone tried it? Good? Playlist finally?
Is the naim native app ever going to support that instead?
Posted on: 24 February 2011 by Paul Stephenson
Yes we will support playlists this year on the naim app.
Posted on: 24 February 2011 by lhau
Wow thanks Paul.
That is wonderful news as I already have the nStream app!
Posted on: 24 February 2011 by Phil Harris
Please remember that "Songbook Naim" isn't a Naim product - it also uses hooks into our code that we have not yet approved for use...
The current Naim iDevice applications are n-Serve and n-Stream.
Phil
Posted on: 24 February 2011 by Tog
Unfortunately Songbook Naim redefines the word flakey - with n-stream you have a team of Naim boffins working to perfect software designed to work with Naim stuff.
Tog
Posted on: 24 February 2011 by Klout10
Hi Paul,
Could you please let us know a little bit more about this update? Do you mean the n-Serve app or the n-Stream?? Timeframe??
Thanks in advance!
Michel
Posted on: 24 February 2011 by rhr
Hi,
I've used it and it is very prone to bugs. The Naim app is far more stable, however, for users of HDXs it has 2 great advantages, it can hook into the vTuner (which I asume is what Phil refers to) so you can stream Internet radio like the Uniti series and it uses the whole screen area on an iPad.
I'll put up with it so I can view more information on the iPad screen. I suspect when the new nServe software comes out I will stop using it.
Also, I've logged bugs with their support and received no response.
Rich
Posted on: 25 February 2011 by gmischol
I purchased it and I do regret it (really pricey). Songbook is so full of bugs, it doesn't really work and with the latest update, nothing goes anymore.
I think it will be worth waiting for the next n-stream app
Posted on: 25 February 2011 by lhau
Thanks. I have nstream already but just want playlist badly
