FAO pcstockton - foobar help
Posted by: Occean on 25 February 2011
I am strugglng to find the old foobar helpdesk post as I know you answered this for me before.
I am using the dark one skin on a 1080p tv and need to increase the font in the album list on the right hand side
help appreciated!
Posted on: 26 February 2011 by pcstockton
Occean,
Go to File>Preferences>Display>ColumnsUI>Color and Fonts
Select Font Tab
In the Element List select "Album List"
In Mode select "Custom"
Then change to whatever you want.
Most fonts in DarkOne can be change here.  If you change a font here but nothing changes on the screen, there might be a "forced layout" situation going on.
In that case you may have to right-click in he area in question and play with the title formatting in the splitter/panel settings.  Or just go on to deviantart and ask Tedgo a question there.  He/She is very helpful.  They helped me fully customize the DarkOne for my needs.
I hope this helps,
Patrick
Posted on: 26 February 2011 by Occean
Patrick
Cheers once again
Eric
