Missing album art
Posted by: Winnie Bago on 29 May 2014
Hello folks
I've been passively frequenting the forum for a little while now, and have garnered much useful information, for which many thanks.  However, I now have a curious problem which I cannot seem to overcome.  Not earth-shattering, but irritating none the less.
I recently upgraded my Synology DS212j to DSM 5.0-4482 and since then the "Recently added" listing shows every album on the NAS (3,896) rather than the last 14 days, which it is set to under the DSM settings.  If one selects an album earlier than 14 days it opens the folder in n-Stream and says the album is empty.  All other settings are working properly, eg "By artist", "By genre" etc. and selected albums play perfectly.  Curiously, if I run DSM Audio Station and select "Recently added", it correctly shows just the last 14 days' albums.
I have reindexed the Synology 'til I'm blue in the face, rebooted, uninstalled and reinstalled n-Stream on the iPad mini and tried all 3 custom menu choices in Media Server, all to no avail.  Does anybody have any suggestions - with nearly 4,000 albums it's a real pain in the bum trying to locate an album that you just bought last week (and possibly forgot the name of!).
Many thanks
WB
Posted on: 29 May 2014 by garyi
Surely as far as the a new NAS is concerned everything you added, presumably at once, is recently added?
Posted on: 29 May 2014 by Winnie Bago
No, I've been running the NAS and a NAC n-172XS / NAP200 for about a year with no problems.  The file created dates on the various flac files vary by over 4 years, which is when I first started converting CDs to HD.
WB
Posted on: 29 May 2014 by mutterback
Who knows which bit of metadata its using for "recent." Different programs use different data. I concur with garyi - because you changed something, its probably grabbing that date. Wait 2 weeks and see what happens.
In terms of the album art - the best tool I've come across is Bliss www.blisshq.com Paid software, but well worth it. Can run through your whole collection, automatically clean up metadata and add art (or attach existing art correctly.) You could also use Music Brainz Picard (free) but its much more geeky.
Posted on: 30 May 2014 by Solid Air
I'm not sure it looks at the file creation date. I suspect the previous posters are correct - at the point you upgraded to 5 it became a 'new' NAS and all the albums were equally recent. In a fortnight your symptoms should clear up.
Posted on: 30 May 2014 by Winnie Bago
OK folks, thanks for the input.  Looking at the tags, all dates seem to be correct, as do the flac date properties, so it's still a mystery.  Perhaps the Synology index file is corrupted and is not erasing old data.  But I don't know where that's stored, dammit.
WB
Posted on: 30 May 2014 by mutterback
I don't want to sound like a jerk, but I think you're missing something fundamental about how and where the data is being stored that - I think - will  help you down the road.
FLAC tag data are stored inside the FLAC files. They are not based on any real standard. Different applications use them differently (and, in fact, you can create your own tags.) There's 2 dimensions to this: the tag labels such as "Artist" vs. "Album Artist" and how the application uses them.  One application could decide to grab "Artist" tag track by track, another "Alum Artist."  Every application you use to control playback needs to suck in the FLAC tag data into its own database to manage browsing, searching and sorting. So, you could change the tag inside the files, and your app still might not update them, or may update them on some schedule (daily, weekly, every hour...)  Your app won't display the changes until it updated its own database.
However, what we suspect you're dealing with here is a 3rd dimension of data.  This data is *outside* the FLAC tags, similar to the "last updated" date on a file on your PC. What we suspect is that the Synology App is using the date from the NAS file system or its own database to control which tracks are "recent" Since you upgraded the NAS, it probably refreshed its own data - whether from the file system or inside the app database - and every file is now being seen as "recent."
You can get all of the FLAC tags right, and your App may still seem to have some errors, or have a lag until it updates its database.
I see metadata as the main hurdle left for the industry to manage better before streaming can become truly simple.  Its one reason why people like the NServe and iTunes - the application you use to control playback was designed together with the way the metadata is stored, and they both clean up the metadata from their own external sources online. If you are using FLAC files and data from lots of sources, and different control apps, inevitably things will get a bit disconnected - which is exactly what you're experiencing here.
My approach is to try to fix it incrementally, as I have time, and/or when something really annoys me, and otherwise just ignore it.  When I get frustrated with all this, I put on an LP
OK, thanks Mutterback, I guess I'll just wait and see if it fixes itself.  It's just frustrating that something that worked perfectly under software version 4, doesn't work under the "new and improved" version 5.  Nothing's been changed except for the Synology update, and it's not possible to wind back to version 4.  Ah well, this is not the first time - I still prefer Windows 7 (or DOS for that matter!) to Win8.
WB
