Unable to play FLAC files on NDX
Posted by: EnataiDan on 30 May 2014
Recently acquired and NDX and looking for guidance on why it's not playing FLAC files.
Here's my setup:
- NDX running 3.22 firmware
- Music currently resides on Win8 pc (sharing files through HomeGroup settings) (will be migrating library to NAS drive shortly)
- Controlling with n-Stream version 3.6.7479
Problems experienced:
- Using UPnP input, n-Stream shows the folders are empty when I drill down into the HDTrack folders that contain a few files I've purchased (I've read posts that recommend copying the folder into the iTunes music library, but get the same result)
- Using USB/iPod Input, I get "Source Err. Press OK To Re-Try". (USB input does work fine with an iPod attached and I'm able to read the FLAC files from the thumb drive on another PC and play them using MusicMonkey)
I am able to play high res AIFF files from HDTrack, just not FLAC files. Before I re-do my CD library on the NAS in the highest resolution, I hoping someone can point me in the right direction to solve this issue.
Thanks,
Dan
