Duplicate tracks
Posted by: rupert on 08 June 2014
Hi I have some trouble with the above going into twanky done a restore then a scan then a rebuild , This solved the problem but given me another some albuns won't play they did before a notice comes up saying they are in the wrong format all are on a separate hdd,I must have done some thing in the settings as I said solved problem given my self another any ideas regards.
