Connecting 2
Posted by: Jonas Olofsson on 10 June 2014
The advice regarding the NDS "connecting" all the time, worked fine (CLEAR catch memory).
Well, now the iRadio dont work. Just says "Just wait", nothing happens...
Everything is connected through cable, no known problem with my ISP.
//Jonad
Posted on: 11 June 2014 by Fokkelman
//Jonad
Do you have a fixed IP address on the NDS? I did, and iRadio didn't work either.
Posted on: 13 June 2014 by Jonas Olofsson
Thank you for your answer. Will check that.
Strange though since it did work for months without any problem.
