Uiticute 2 - radio stations keep stopping?
Posted by: Pauleb on 24 June 2014
I have a Uniticute 2 which is connected to the router via a switch and Cat6 cables.
For some reason radio stations keep stopping and I need to press play to reconnect.
My broadband appears to be stable at around 6 - 6.5 Mbps and a VPN connection for work drops only very occasionally.
Can anyone offer any ideas as to why and could it be the Cute and not the broadband?
Thanks in advance.
Paul
Posted on: 24 June 2014 by steven2907
Hi I had the same problem with my unitiqute supernait set up. Turns out my problem was that the qute was set to mute. So after just under 5 mins it drops the connection.   This may or not be your answer but was mine.  Hope it helps
