ipad
Posted by: rupert on 29 June 2014
hi Can any body help may be a geek i send mail out on my ipad replys dont come back on it,But onanother pc on my network virgincant solve it any ideas regards
Try forwarding your received mail from the other PC, it should arrive then. Other forums may be a better option with non Naim / music specific queries.
I use the same e-mail address for iPad as my PC & have both sync'ed so I can write & read the same e-mails on both devises. If I write/move to folder/delete a mail in PC it does the same on the iPad
In the iPad you have iCloud e-mail, set your PC e-mail address as the default mail for the iPad.
Activate & keep iCloud but don't use it, add your PC e-mail address as default.
If you have done this correctly under the Mailboxes list (keep left swiping the mail side banner until it won't go again)
The "Mailboxes" side banner & will list "All inboxes, your e-mail"@"address, VIP, Flagged, Unread " .... etc
Then at the bottom of that is a box called "ACCOUNTS" under that you will see iCloud & if your've done it right you should see your regular e-mail address. Just be sure that you only use that address & not mistakenly iCloud.
I feel you may be speaking Swahili to an Inuit.
I could be wrong.
Whats your point, my wife used these same instructions & is up & running!!!
BTW, I speak swahili quite well but need to work on inuit, Tavvauvutit
I get it, (hint) it's got nothing to do with the quality of the advice... ![]()
I could be wrong.
