Naim HDX works with exFAT formatted sticks?
Posted by: teofil on 17 March 2011
My Naim HDX player now works only with FAT and NTFS formatted memory sticks. How can I upgrade my HDX player to work with exFAT formatted memory sticks (because these sticks has a bigger memory)?
Thanks.
Posted on: 17 March 2011 by garyi
Not sure what you are getting at, but even very large memory sticks can be formatted as fat 32, just format it as fat 32. I have happily formatted 1.5tb HDs as fat 32.
Posted on: 17 March 2011 by Affinity
The limit on FAT32 that you're thinking of is probably the file size limit. And i guess you don't have any songs that is over 4 GB.
From wikipedia:
"The maximum possible size for a file on a FAT32 volume is 4 GiB minus 1 byte or 4,294,967,295 (232−1) bytes. Video applications, large databases, and some other software easily exceed this limit. Larger files require another filesystem, such as NTFS."
