Unity / I pad
Posted by: Steve w on 08 August 2014
Excuse the daft question, but if I wished to connect our I pad to the unity ( I have an apple multi pin to phono lead ) which would be the most suitable input to use ? I have tried analogue 2 ...the volume is much reduced. ..this is just for the odd spotify session .
Posted on: 09 August 2014 by Huge
To the best of my knowledge, the Naim USB input will only read stored files from apple devices, not audio streams.  For that use, is is just plug and pray.
For streamed audio I believe you do need to use an analogue connection.
Posted on: 09 August 2014 by Sloop John B
you certainly can stream qobuz through the nDAC by USB connection of an iphone. I'd imagine it's the same with the Uniti. You may have to have Spotify running on the iDevice as you connect.
I believe the situation for the nDAC is not the same as for the streamers.
Indeed I cannot seem to replicate it with my UniQute.
SJB
