Will a Cat7 give me better SQ?
Posted by: Fredrik A on 17 August 2014
I currently have two Naim systems, one with UQ2 and Dynaudio Excite X14 and one with Uniti2 and right now Elac FS247 but soon Dynaudio Focus 160. The Uniti2 is located together with the TV so my BD-player, DVB-T-box, Apple TV 3 and Tvix are all connected to it through the digital inputs.
My home network is Apple based, right now consisting of three AirPort Express since a thunderstorm tok my AirPort Extreme. I use one of the Express as a repeater/access point close to the UQ2 and connect the UQ2 to it with a no-name Cat6 STP, the Express is connected to the main router via Wi-Fi.
Would a Cat7 STP give me better SQ or is that meaningless since i already use Wi-Fi between the routers?
I would probably buy a Supra Cat7+, since I live in Sweden about 30km from the Supra factory. I like Chord but the C-stream is twice the price of the Supra here in Sweden.
The Uniti2 has a similar network setup, only difference is a Zyxel switch between the AirPort AP and the Uniti2.
Hej Fredrik, I think the answer is it depends - on your ears & your system & if you believe an ethernet cable actually has a sound. IMO a low spec cable can introduce noise & other effects that degrade SQ, whereas a Cat6 or Cat7 has a higher & tighter spec & in theory at least should be able to give better SQ.
When I was planning to get a network player I chose Supra Cat7+ because I had the impression it sounded better than a no name Cat something, but I listened on a friends Linn system. We compared it at the same time with other Cat7 & I did not detect a difference that I was that sure about.
I have not changed the Supra since I installed my NDX so its hard to say. But as it happens, last night I installed a 1m length of Cat5e to experiment with the effects of grounding or not grounding Cat7 & there was a difference - not a good v bad, just different, but was it the effects of the ground v no ground or the cable, I don't know. (see my recent posts on the grounding subject)
Regarding Supra Cat7+ it is for sure a high performing cable, its 1300MHz bandwidth is way more than needed for our systems, but no harm in having it. But its not the prettiest cable & it does not bend as freely as some others. I would keep that in mind at least.
I broadly agree with Mike's comments.
Unlike analogue or S/PDIF signals, the music signal in a network isn't real-time. Unless the data transmission is faulty, the data signal doesn't affect the sound. However, the cables do affect the way the system responds to RFI, and that does affect the sound.
The minimum spec of cable for an audio network is Cat5 as Ethernet streamers use 100Base-T for their data standard, however cables of higher category tend to be more precisely made and this can give better RFI rejection.
I note that you haven't said what your storage system and UPnP server are or how it's connected.
Some people have found the Apple Airport system to limit sound quality, and this may well be more of a limitation than the Cat6 cable. It's possible that the Airport system introduces a certain amount of interference into the audio system through the connecting cables.
The other point about cables Cat6a and above is that they tend to be shielded (STP, SSTP, SFTP), this again can help reduce RFI, provided that the shields are properly terminated. On the other hand, the problem with shielded cables is the possibility of earth loops. Do you know if you have much RF either conducted down the mains or through EMI? If so fixing this will be of considerable benefit, but this does mean getting it right.
Many Apple Airport Extremes in use here in the woods - no limit on sound quality as far as I can see.
Cat 6 - switch - server
Tog
Tog
No Airport Extreme since his died. He now has 3x Airport Express, with some connections wireless. Without precise details it's impossible to be certain what's best for improvement - hence my 'generic' rather than specific suggestions.
I have no idea what this is about. Do you mean in comparison to other wi fi solutions, or a wi fi vs. wired comparison, or . . . ??
Take it in context of the original question.
...Compared to a wired connection - to whit Cat7 (or others!).
Thank you for your replies.
Here's my total network chain
Telia ADSL modem & Synology DS411 NAS - Cat 6 UTP - Main AirPort Express - Wi-Fi - AirPort Express Repeater/AP - Cat 6 STP - UQ2
Main AirPort Express - Wi-Fi - AirPort Express AP - Cat 6 STP - Zyxel ES105A - Cat 6 STP - Uniti2
I'm to replace my broken AirPort Extreme with a new one just waiting to see if Apple releases a new one together with the next iPhone or iPad.
Just to make my self clear: I will keep the wireless connections as they are.
Ah, thanks for the clarification.
If you have to keep the wireless, then the Apple solution is better than generic WiFi, so I think the only two things you need to check
First is the possibility of earth loops
1 between the Airport Express and the UQ2
2 between the Airport Express, the ZyXEL switch, and U2
Second is the possibility of RFI
1 the cables connected the UQ2 and U2 (except speaker cables)
2 the SMPS
Huge, what are you referring to as 'generic' wifi? Apple wifi implementations certainly can have issues when you are trying to do certain things.
For streaming (UPnP/DLNA and Airplay) the area of support that can be troublesome is multicast data, and Apple and many other quality wifi access points support this.
However Its with the area of bundled wifi, as with bundled switches, that with some cheap broadband access routers where there appear to sometimes be implementation issues with multicast. Is it these cheap bundled wifi access points you are referring to as 'generic'?
Simon
Simon
Yes. I use the term loosely for systems based on the IEEE802.11.g equipment delivered in bundles with a broadband package (usually the cheapest thing the broadband provider can source). In addition to the quality of the equipment itself (and the attendant RFI problems), the 2.4MHz band usually has more contention issues than the 5MHz band that's often only supported by better equipment. I've just also realised that I should have actually specified the Airport Extreme over the Airport Express).
Form other reports on here I get the impression that the Apple equipment may be creating fewer RFI issues for users, but this is just an impression garnered from other's posts, not based on hard fact.
I used the term 'generic' to avoid any perceived insult (which is specifically not intended).
You're an M short of a G ![]()
Simon, (and with apologies to the OP for a hijack)
May I ask a point of detail about switches (for the config guide I'm writing)?
My understanding is:
L2 Unmanaged - passes Broadcast data packets to all active ports, but 'learns' to pass data packets that specify an endpoint only to the port where that endpoint is connected.
L3 Managed - allows the network admin to specify which classes of data packet (selectable using both Layer 2 and Layer 3 characteristics) are passed to which port. Is the programming done by port, by endpoint ID or by either?
(I know L2 Managed also exist, but for this use they seem to be a less good compromise - they still need programming, but don't offer identification of packets on Layer 3 criteria).
Are these correct? I tend to understand principles for a lot of stuff, but when it comes to specifics I often need to seek advice from those who really know in depth!
The switch send the broadcast frames out of all active ports on the same network or VLAN . If a switch does not support VLANs it will send the broadcast frames out of all active ports.
A switch learns and constantly checks the association of Layer 2 network addresses to specific ports so it knows which ports to send the frames to. A broadcast frame has a specific broadcast destination address which is understood as a special address by the switch.
For many consumer switches multicast frames are handled the same way as broadcast frames
A switch is a layer 2 device and handles Ethernet frames and not packets.
Layer 3 refers to the TCP/IP transport layer and works with data packets. A L3 packet is encapsulated within a L2 frame.
A layer 3 function includes routing. Routing allows the flow of data packets from one network to another - such as your internet access network to your home LAN or between VLANs on your home LAN.
Packets and frames have source and destination addresses. Packets have source and destination IP addresses and frames have source and destination network or MAC addresses. A network or MAC address is only deliverable within the same network or subnet. For the data to pass between networks or subnets the source and destination IP addresses are used and the router handles this function.
Essentially the layer 2 network address is used to deliver the frame to the router and then the router looks at the IP addresses to see where to send the packet.
A 'Layer 3 switch' is a combined switch and router.
The term of managed and unmanaged largely doesn't define the functionality of the switch but typically refers to the ability to 'manage' the configuration ie bespoke its operation in some way - I think what you refer to as programming. The programming can be applied to many different aspects of the network, frames and packets - and is subject to the capability of the switch
I hope that helps
Simon
Huge - might be better to progress over in padded cell
<ACK>
