Toslink woes on UQ2 solved
Posted by: BigRooster747 on 26 August 2014
Hi all,
just a quick note to say my toslink woes are over. The heavier ones will not connect to the unitiqute2 slots, since the receiving end on the Qute seems to be recessed some. The shoulders of the connectors of the heavier ones are too wide to get them seated deep enough, hence a loose fit.
I found a very thin cable (3mm) with thin connectors that do fit and click into the receiving end on the unitiqute with a positive click! It's the DeltaC/Dynamic high quality brand by www.deltackabel.nl. Part number is 543. 1,5 meters for 10 euro's. Probably to be had cheaper somewhere.
