Updating my NDS
Posted by: DQ on 23 September 2014
All,
I am a few versions behind on updating NDS. I think I am on 3.1. Two questions
1. Is it just a simple USB cable to update
2. Do I still need to do all the updates in order of the relaases?
Best, David
Posted on: 23 September 2014 by Bart
David, the usb cable is the simplest way to do it.  The serial cable route is a little more tricky, as it requires a compatible cable.
Be sure to check with Naim tech support about which updates can be skipped.
Posted on: 23 September 2014 by Harry
I didn't know you could do the NDS with a serial cable. I use a bog standard USB to mini USB and although time consuming, all updates have gone smoothly.
I wasn't aware of any skips but the app update software will advise you of what updates are which. I think it will only let you do them in the appropriate sequence?
Posted on: 24 September 2014 by DQ
Thanks both....USB cable in hand I will go at it!
