Back Up NAS
Posted by: Camlan on 26 September 2014
After much deliberation I have now acquired a QNAP NAS and finally backed up my Unitiserve to it. The process of set up was initially simple using the knowledge base procedure but I did have a major problem in allocating the Naim Backup file as the designated back up destination as Nserve simply refused to do this.
The solution for others who may have this issue is to ensure that the file you are designating is completely empty. The QNAP NAS allocates a recycle folder when you create the file and this must be deleted before designating the file as the backup. Thanks to Hungry Halibut and his Synology thread which I finally found for this solution.
A quick question for the experts if I may. Nstream is now showing the QNAP UPNP stream as well as the Unitiserve. Do I need to disable this or does it make no difference?
