Newbie Questions
Posted by: NeilF on 29 September 2014
Hi all, bought my first ever bit of Naim kit on Saturday and just joined the forum today. I've had a quick search around but can't find any obvious answers to a few questions, so thought I'd ask here. I've got a brand new Unitilite and it's a doddle to use and sounds lovely. Questions are about the Naim App - it's different to the App I used in the shop and when I first started it up I wasn't sure it was meant for the Unitilite at all. But I can't find any other Naim apps so presume there only is the one.
1. Is there a Help facility anywhere on the App? Some of the options that can be selected in the setup pages could do with an explanation, as I don't understand what they mean. For instance, there's a tick box for "Use Streamer's Language". I've ticked it and everything seems to work, but why might I want to use a language the streamer doesn't understand?
2. Getting the App to find my Unitilite seems to take about half a dozen goes before it appears. Is this normal?
3. I've put the App on two iPads. If I've been using one the the other can't find the Unitilite. Is that normal? If I select "stay connected" on one iPad will it completely lock out the other one?
4. How do I get the album artwork to display? It's all there on my Synology NAS and it works perfectly on my little Marantz streamer.
5. Is there an easy way to search for radio stations? I've tried just putting the station name into the search box but that doesn't seem to work. And now I've lost any means of getting new stations - just a blank page on iRadio so no way to select country/genre.
