naim app fails constant
Posted by: Naimpy on 09 October 2014
hello everyone,
I have a dramatic experience with the new naim app. it stops working time after time. It keeps comming up with a screen "rooms" and a startup for multi room. I do not have any multiroom stuff just one nd5xs.
With the previous nstream app this worked really well!! Now with the new app, it is very bad.
I use a sygnology NAS, the ND5XS with the latest firmware 3.22 UPnP connection. I keep on restarting the ND5XS and / or the network server. Afterwards it works for several songs, and agian it fails. It looks like the app does not want to work with my NAS. The connection on the ND5XS with the server is okay,  via the display I controle without any problem.
What is changed in the new app, am I doing something wrong?
Anyone?
Posted on: 10 October 2014 by CP62
Hi Naimpy,
same problem here. i am talking with Phil and Steven about this problem.
Hope this will be solved fast. Will let you know.
Greetings from Holland.
Posted on: 10 October 2014 by Naimpy
Hello CP62,
Phil contacted me as well and we are in contact.
First approach : put the app in compatibility mode. This seems to work although you loose functionality.
Apparently Phil knows which button on dashboard to turn.
Next step should be the final solution with restored functions. Keep you posted when new steps become available.
Peter (also from the low lands (achterhoek))
Posted on: 16 October 2014 by Thomas Breding
..have similar issue: have been running the new app with my UnitiQute2 since the app came out. Everything worked well until today.
Now the app can´t "find" the UQ2 and even if I try to add it manually it can't find it. UQ2 runs fine and plays music from my NAS, using the remote but app does not work on iPad and iPhone.
Have restarted EVERYTHING multiple times.
Anyone had similar issues = everything running well until today?
Posted on: 16 October 2014 by Paul Stephenson
What iOS are you using or android?
Posted on: 16 October 2014 by Naimpy
Dear Paul,
I am using IOS 8.0.2 on an iPad . Also an iPhone 6 with same IOS is used giving the same results.
Peter
Can't say for sure - we are working on various issues as we launched the app at the same time as the iOS upgrade.
See sticky at the top of streaming section.
Cp62 isn't your problem related to your netgear router and you are waiting for a replacement?
Posted on: 16 October 2014 by Steve J
Naimpy,
I had the same problem and it's due to iOS8.2. Go to Settings>Privacy>Location Services>System Services and turn off Wifi Networking. It worked for me.
Steve
Posted on: 17 October 2014 by Fokkelman
I am working with iOS 8.0.2 without any problems.
Posted on: 17 October 2014 by Naimpy
Steve,
Thanks for your suggestion in this matter! Yesterday evening I did exactly what you said helped for you in IOS8,2.
I added the next steps:
  1. erase existing wifi connection from my device iPad / iPhone
  2. changed the setting as you discribed
  3. restart the iPad completely (make sure the new setting becomes effective)
  4. made a new connection to the router.
Result : no change at all. The NAS can not be found, the app keeps searching endlessly.
As soon as I change the app settings for UPnP to compatibility mode; the NAS is detected immediatly and works.
I am not an expert in this field, but to me this proves that the app and not IOS is the cause, don't you agree?
Peter
Posted on: 17 October 2014 by Steve J
That's odd. I hope you find a solution soon. One thing I did was to load the app on my wife's iPad which was running iOS8.1 and it worked fine. I then deleted the app on my iPad and reloaded it with the change of settings above. It's worked fine since.
Posted on: 17 October 2014 by Andrew Gavriel
I am having a number of issues also, my unitii2 is returning triple names for all songs and actually playing each song 3x. Not sure what I have to do to reset this. Have also had trouble with the new app just not finding songs on my PC that I have ripped recently.
Posted on: 18 October 2014 by sondek71
I have exactly the same problem, worked until today. Today it seeing my NDS but searches endlessly until it says that another app is already connected to the device or that the device cannot be found. I am on iOS 8.0.2, nStream 4.1 and NDS Firmware 3.22. I am back to the Remote Control.....and wait until iOS 8.1 on Oct 20th. If things do not change by then, I will get in touch with Naim Support again. It's getting on my nerves: How can someone spend like 15k on equipment and not get a proper software along with that....
Posted on: 18 October 2014 by Fokkelman
I think iOS 8 is the culprit. Though all works fine for me with iOS 8 other apps I have crash since the iOS update.
Posted on: 18 October 2014 by Naimpy
Fokkelman and sondek 71
have you tired to change the app settings for UPnP to the compatibility mode?
It is not what you want for a final solution, but for me it makes the app work on a minimum level.
it is better than nothing at all, and I agree that the current situation is absolutely Naim unworthy.
Peter
Posted on: 19 October 2014 by phosphocreatine
Have a ND5 XS upgraded to 3.22 firmware.
With my IPhone 6 everything works flawlessly but with my IPad Air upgraded to Io's 8 (by formatting the whole IPad from 0) every time that I I go back to the Naim app I have to turn off and on again the app because it freezes (it isn't able to go again on the playlist).
Hope new version will be more stable !
Posted on: 19 October 2014 by sondek71
Peter
How can I do this? I have not found this setting....thanks.
Posted on: 19 October 2014 by hungryhalibut
Settings, input settings, upnp. In the app. Press the spiky round thing at the top right on the front screen.
Posted on: 20 October 2014 by sondek71
I have now found the settings, but to get there you need to have a connection to the streamer. I didn't even have this, so no settings:-((
Now - as I have installed iOS 8.1 last night - everything is working again. At least I now had two consistent connects to the streamer. Let's see whether this state is sustainable.
Posted on: 26 October 2014 by sondek71
Obviously the state is not sustainable. 4th test with iOS8.1 was negative. I can sometimes connect to the streamer but it loses connection again within less than a minute. I can start a radio stream and then nStream comes back with "Cannot connect to the streamer. Options: OK or want to try again?". The sign I can see most of the times ist the turning ring doing something I cannot sort out. Am I the only one with this kind of problems? Cannot imagine....neither can I remember having signed up for the beta testing program....
Is there a debug mode for the app to at least find out what it's trying to do? The app is really turning the hardware equipment useless at the moment, so please Naim get this sorted out quickly. Thanks.
Posted on: 26 October 2014 by Naimpy
Sondek71
for your assurance, No you are not the only one. Here I still have the same problem. After resetting everything it works for some minutes and then I loose connection. As I started this thread : drama all over.
I talked to my dealer who will contact the importer for Holland to get some help.
I will post any results here.
Peter
Posted on: 01 November 2014 by sondek71
I have now exchanged my whole wireless network. No change at all....the mu-so app still doesn't recognize my NDS. I am now using 8player to get the NDS playing. It somehow seems odd to me that I have to use a third party software to control my equipment. Not quite like I expected high-end to be these days.....waiting for the next beta release of Naim...if problems are not resolved by the end of the year I am gone.
Posted on: 02 November 2014 by Naimpy
Here the same.
I have installed the DS audio app from sygnology and it all works flawless.
The NAS is recognized and can I play it all on my ND5XS.
It now really becomes time that NAIM starts to solves this I do agree with you.
The Muso has been introduced, so now get back to solve the app please!
Peter
Posted on: 05 November 2014 by mcsucker
I have the same problem but strangely the problem does not appear when using an iPad mini!
Posted on: 05 November 2014 by sondek71
My problem seems to be resolved - for at least 2 days in a row now. Strangely I do not know exactly where the problem came from. I reset the network settings on my iOS devices and attached the NDS directly to the WLAN router in wired mode. Get in contact with Tom Johnson of Naim if the problem still consists. There is a tool called NetAPIIA which is able to debug the communication on a protocol level between your UPnP Server and your Naim equipment (fiddling around yourself is inefficient). I am on a all Mac environment and to be honest I am not sure whether the fault is caused by Apple's iOS or by Naim's app. The combination however does not seem to be very synergetic.
