Disabled reset streamer function
Posted by: Roal4151 on 11 October 2014
Why this very useful feature has been discarded?
Doing so mean that if someone has his streamer in a place where he can't reach easily his power switch in the back, he will have to empty his cabinet to reach the switch, or worse, if he has his streamer on another floor, he will have to get there to fix the issue of possible disconnect of the  streamer from the router when you are in wifi or wired configuration.
Really don't understand why that has been changed.
Posted on: 11 October 2014 by sjbabbey
If I understand correctly the "reset streamer" function is not simply a reboot of the streamer (similar to switching off and on again) but will reset the streamer back to its factory settings and quite rightly naim decided that this should only be done via the streamer's own settings menu where a warning would be given.
This function was not available on the old nstream app.
Posted on: 13 October 2014 by Phil Harris
Correct... It was a reset to factory defaults and so, after much discussion, has been removed from the current app.
Phil
