HDX SSD Won't Rip
Posted by: Victor12 on 12 October 2014
Hello All,
I have a HDX SSD that I'm using with a Synology DS114 with a 4tb hard drive. I can't get the HDX to rip CDs to my music store on the Synology.
Everything seems to be setup correctly and working normally except ripping. I have music shares on the Synology that the HDX plays fine. I've upgraded a music share called "NAIM_MUSIC" to a music store and set it to top priority. When I try to rip a CD I get a "not enough space to rip CD" error. There is over a TB of free space on my Synology, when I check the music store status it shows over a TB free space on the HDX touch screen, so it seems like the HDX is communicating with the Synology music store just fine and it sees free space but it won't rip to the Synology. I tried promoting one more music store called "naimmusic" with the exact same results. I transferred a CD into the music store from my PC and when I check the status of that music store it shows 1 CD along with the correct amount of free space on my Synology, again, this seems to show it's not a communication issue. I tried setting up my Synology with and without a password with no change. My HDX is at software level 1.7a sp1 and my Synology DS114 has no programs or files on it except my music files and the base Synology program that is loaded when the Synology is new and first started. My modem/router is a Netgear B90, I've also tried an older Apple AirPort Extreme (the old flat one), same exact results with both modem/routers.
Any help with this would be greatly appreciated.
