NaimUniti Upgrade Options
Posted by: stammerman on 19 October 2014
I have one of the first Naimuniti's from May 2009 and it has served me well
! Apart from upgrading the firmware (running 3.22) mechanically there has been no faults until very recently. Although the CD player has had minimal use, it now won't play any CD's. For each CD there's a an initial spinning of the disc and the a few seconds later the display shows "NO CD". I thought it might be the puck so I've replaced it but still the same. Any ideas?
Also, bearing in mind that the Uniti is now 5.5. half years old are there an hardware upgrades worth considering or should I consider selling the version 1 Uniti and getting something else? 99% of the music I listen to is streamed together with some internet radio.
Advice would be much appreciated!
Martin
