Qute + nDAC = 24/192 UPnP?
Posted by: okli on 25 March 2011
Hi okli
Your thoughts are correct; the 24/96 limit remains. However, there is a great benefit to the sound, as you might expect. ![]()
Hope you are well
Peter
Hello Okli
Glad you are OK. I don’t look at the forum that much now. I find it difficult to read for any length of time as it causes my vision to blur after a short while. I use a netbook with a 10” screen, that and age are not helping I suppose.
I think you may well be right again if you do try the nDAC. It took us all of a minute or so to realise its benefits and to decide to buy one. Ours is hooked up via a DC1 cable and never seems to be off.
Another word of warning, it didn’t take any longer to decide to add an XPS to the DAC (I flatly refused to try a 5 series PS)! However, I would say the DAC was the bigger single improvement.
Good luck and regards,
Peter
Hi Peter,
thanks for the valuable info - will try to stay away from power supply offerings :-)
regards,
Ilko
Low chances.
The old wizdom says if there is a plastic 5 $ plug on the Naim back panel it will be updated to 5000 $ aluminium "plug" one day ![]()
AMA, I'm afraid you are quite right, but I'll try to be hard to myself and resist the willing to get PSU... at least for the moment ;-)
Hi Okli
There you go!
With us it’s usually my wife that picks up improvements first; always been that way.
But yes, the difference is undeniable (unfortunately
), but then what else would you/we want to spend our money on? ![]()
Are you hooked up with a DC1?
Enjoy the rest of the demo time; you will hate having to hand it back though.
Best regards
Peter
P,S, Have you seen that a new version of iStream/Pad app is available and it appears now free from yesterday?
