Desktop Client for Mac
Posted by: KRM on 31 October 2014
Does this exist or did I dream it?
I want to be able to control my Unitiserve, run scans of shares etc but I can't find the app on the main website or app store.
Do I have to use creaking old laptop?
Keith
Posted on: 31 October 2014 by garyi
shows in the app store just fine, type in 'naim'
Posted on: 31 October 2014 by KRM
Hi Gary,
Found nServe but not DTC.
Posted on: 31 October 2014 by J Saville
N-serve for Mac OS is DTC for Mac. If you click on the name of your Serve in the top left you will find a drop down menu with the same options you get in DTC.
J Saville
Posted on: 31 October 2014 by Jude2012
Keith, do you mean the web based access? If so, it will work on Mac, Windiws, Linux,, etc. I'm sure the User Manual on the Naim site has the details.
Jude
Yes on mac Desktop Client is called nServe, I believe this was done purely to confuse people
The DTC has a Tools section. Where is that in n-Serve for Mac?
Click on the Serve's name top left, drop down menu, 'Maintenance'.
Ha! Blimey, it's like Platform 9 3/4! Thanks Gary, mystery solved.
...and thanks J Saville.
