Oppo 83SE freezing
Posted by: Dungassin on 11 November 2014
My Oppo 83SE bluray player (multiregion for DVD and bluray) has been having fairly frequent episodes of 'freezing' while playing back DVDs.  I suspect it may be 'dying'.  Anyone suggest anything to improve things and perhaps avoid the need to replace it?
Posted on: 11 November 2014 by Dungassin
Just did a little bit more research, and have cleared the persistent storage cache on the Oppo.  Hopefully that will cure the problem.
Posted on: 13 November 2014 by Occean
Out of curiosity how is that done?
Posted on: 13 November 2014 by Dungassin
Most of the freezing problems (for other people) seem to occur with bluray discs.   If you have a problem with bluray discs freezing, first you turn off BD live (if it's on!) before clearing Persistent Storage :
Eject Disc tray
Setup > Network Settings > BD Live Network Access > Off
To clear Persistent Storage :
Setup > Device Setup > Persistent Storage > Erase Persistent Storage.
Since doing this I have not yet had a repeat of the freezing disc problem with with Bluray or DVD.  Also (hangs head in shame), after finding this out (again) I remembered that I had to do it a couple of years ago.
