NDX, nDAC and 555PS - Some Interesting Tests
Posted by: Asenna04 on 28 March 2011
I have been testing the new NDX over the last few days. My system is as follows:
SB Touch / USB Memory Sticks
nDAC
555PS
Hi-Line
252/Supercap
250
NAC A5 Speaker Cable
Ovator S400
The are 3 Powerlines on 555PS, Supercap and 250.
I let the NDX powed up and conencted to UPnP source and playing on mute for a few days.
Test 1 - NDX/555PS
I replaced the nDAC with the NDX powered by 555PS. The SQ was not on par with nDAC. It seemed the nDAC has more top end detail and tighter bass.
Test 2 - NDX
I then just decided to run the NDX on its own without the 555PS. The sound was much better. Better even then the nDAC/555PS. This got me confused. Sure that cannot be true. I scratched my head and wondered what be wrong. So I proceeded to Test 3.
Test 3 - nDAC
Based on what I found on Test 2, I decided to run the nDAC on its own without the 555PS playing from USB Memory. And again, I got much better sound then nDAC/555PS. So this pointed to setup or problem with 555PS. I checked the Bundy cable and it was very close (resting on) the power plugs where they connect to the wall sockets. The Hi-Line was also very close. So I moved them and the Bundy was well clear of all power cables and the Hi-Line was moved away as well.
This made a big difference to the sound. The nDAC/555PS sound much better then the nDAC on its own. Better timing, better top end, and bigger and tighter bass. This was a huge revelation. Everything was sounding great.
Test 4 - NDX Digital Out into nDAC/555PS
So I now connected the NDX playing from USB Memory with its digital out into the nDAC/555PS (via BNC to Phono Digital cable). I could not hear any difference between that and nDAC/555PS (Test 3)
Test 5 - NDX Digital Out into nDAC/555PS Vs NDX Analog Out
Now it gets interesting! With setup as Test 4 above I added a spare standard Naim lavender interconnect to connect the NDX Analog out to the Tuner signal input of the 252. The nDAC was still connected via the Hi-Line to the CD signal input of the 252. The NDX was therefore outputing both digital and analog signals. The digital to nDAC/555PS and Analog to 252. The digital signal went into nDAC/555PS and the analog output of that went into 252.
The results were shocking. I could not hear any difference when I switched the signal on the 252 via remote between the NDX and NDX/nDAC/555PS. I tried different tracks and the same the results was same. I could tell them apart.
I scratched my head again. If the NDX was sounding similar to nDAC, that would be fine. But how can the NDX sound the same as nDAC/555PS. Not even the Hi-Line was sounding different to the standard lavender interconnect! Shocking.
What does this mean? I could not come up with any possible explanation.
Test 6 - NDX/555PS Digital Out into nDAC Vs NDX/555PS Analog Out
After the shock of Test 5 above, I moved the 555PS to the NDX with the digital out still connected to the nDAC and analog out to 252. The nDAC was still connected via the Hi-Line to 252.
Results? I could not tell any difference on sound quality as in Test 5. But the big surprise again was that when I switched between the NDX/555PS signal on the 252 and the NDX/555PS/nDAC signal into the 252 I could tell them apart.
I could not believe it so I decided to do a blind listerning test. I asked my 8 year old daughter to help me. I asked her to decide which input on the remote was A and which was B and not reveal her decision to me. I then closed my eyes and asked her to switch to A or B. So now I did not even know which source signal was playing and switched between the two a number of times for different tracks. I could not really tell them apart, so picked what I thought was a better source and said A was number 1 on the remote (NDX/555PS/nDAC). I got it wrong, A was NDX/555PS.
What next?
So now I am confused, am I doing something wrong. Is this because the way I am running the test that is affecting the SQ of the results to be same? Surely not. The Analog signal is made in the individual boxes.
As for the Hi-Line, I thought maybe the Hi-Line was making up of the lack of 555PS on the nDAC. But this does not explain why the NDX would sound the same when the 555PS was on the nDAC.
This gives the conclution that the 555PS makes no difference to the SQ and the NDX is as good as the nDAC. But I have heard the nDAC get better when the 555PS is added to it. This makes me wonder if what I heard was real or percieved. Surely it is much better to hear any difference when you simply switch between different signals and play the first signal and then stop and play the second signal.
I got the NDX to test against the nDAC and decide which to keep. I did these tests last weekend and I am still thinking what I should do. But I am very confused now.
Request
To validate my findings, I would like to request other forum members who have the NDX, 555PS and nDAC to try Test 5 and Test 6. All you need is an extra interconnect (ideal if you have another Hi-Line). I know from other forum posts that aysil has all 3 and and some members who already have nDAC/555PS are planning to get the NDX.
ASenna04
Posted on: 28 March 2011 by fixedwheel
After finding the problems at Test 3, why did you not restart the tests at the beginning. You have effectively said that the tests 1 & 2 are invalid due to the poor setup.
I'd also question the validity of Tests 5 & 6 due to the compromised earthing that comes with having multiple connections in place at one time.
HTH
John
Posted on: 28 March 2011 by Asenna04
Originally Posted by AllenB:
ASenna04
Both you and Aysil have now reported relatively big differences, which IMV were not to be expected. So we all need to get to the bottom of this
Allen
Allen,
You are correct. I need to do Test 1 to Test 3 again. I was planning to do that.
But since I have not done that, I cannot claim there is a big difference between the NDX and nDAC. There was a major improvement after I had sorted the cables after Test 3, but that was an improvement in my normal setup that was compromised because of the cables.
ASenna04
HTH
John
John,
Agree, need to do Test 1 to Test 3 again.
Your point about earting is interesting and could be a possible explanation. But I don't expect it to make the two signals in the 252 to sound exactly the same. I believe I have both on selected to be chasis and must not be right since from what I know only one should be on chasis. I will try with different settings and see if it makes a difference.
But surely you should be able to have multiple signals into the 252, it is designed to do that.
Thanks for your comments.
ASenna04
Posted on: 28 March 2011 by lhau
Assenna,
Your test is all wrong for one simple reason, it is flawed like all double blinded test.
What you really need to do is, listen to one setup for extended period of time.
Switch, listen another for extended period of time and only then, decide which one you prefer.
When I auditioned the nap200 at the dealer, I could tell them apart by only very small margin, due to the time straint and stress. I bought it home, and in three days, I can properly perceive it's depth, it's control and grip and would never switch back to the uniti alone.
Maybe my kit is not the same level as yours, but I do know that switching back and forth is not going to help you decide. At your level, the difference is subtle yet important, I think you really cannot a/b it in double blind. At most, you can double blind yourself but for a week, not a track or two.
Ihau,
I agree that it may be difficult to listern to subtle differences in a Double Blind Test doing A/B comparisons. But the systems I was comparing in Test 5 and Test 6 were not subtle, an 555PS is not supposed to add a small difference. Most people have posted on this forums describing jaw dropping change in sound quality right from the first few secounds of playback when the 555PS is added.
ASenna04
Posted on: 28 March 2011 by AMA
In my system nDAC and nDAC/XPS sound as very different players and one does not need prolonged listening experience or double blind test to pick up the difference.
Posted on: 28 March 2011 by sbilotta
Just to add, when I A/Bed NDX with and without 555PS the difference was clear... actually very clear. Less so when the nDac alone was paired with the NDX.
Posted on: 28 March 2011 by matpip
My takeaway of this very interesting post is that adding a PS555, which costs something like 6K euros, is only capable to bring little improvement to a DAC or NDX, so little that just changing the cable dressing can make it even harmful...!!
Guys, the more I read these the more I think that balanced one/two box solutions are the best (see linn streamers), all these sophisticated cables and power supplies upgrades are a very good marketing tool to keep people hooked and willing to continuously look for the ultimate upgrade!
Buy once, buy good and then listen to music, not to gears....IMO of course.
Posted on: 28 March 2011 by james n
Any idea when you'll get your hands on the NDX Allen ?
James
Posted on: 28 March 2011 by Orfeo
Asenna04.
What you have said is really strange...
perhaps are the Ovator400 that are not to much a reveal speaker? ( i dunno these speakers)
252+250 is a beautiful system. I've the same with the Kharma 2.3 and, belive me, you can hear big differences with minor changes..
I'm agree that what you have to do is some long listening sessions.
and keep us posted.. I'd like to go for the NDX on day so your opinion is quite useful
BkkB
Posted on: 28 March 2011 by -goat-
In my experience this kind of a/b testing is a bad approach. I have tried this a number of times with various pieces of kit and at best I have only ever found it confusing. When is it that music is most enjoyable? I find the times I gain the greatest pleasure and insight are when I am relaxed and in the right head space for the particular album I decide to throw on, even better... at a gig with a good bunch of people etc etc. Endlessly switching back of forth like this you are probably only going to apprehend superficial differences if at all. You may hear a change in presentation but in terms of discerning worthwhile musical improvements I find this approach generally hopeless and frustrating. The other point worth making is that any pieces of kit that are new will throw in a huge variable. I have on occasions even found second hand kit to be unpredictable for the first week. IMHO better to keep any comparisons simple and give your self a few days at least to decide whether you are gaining any greater enjoyment. I almost always find the answer becomes clear after a few days running. Other folks' experience may be different of course but my advice would be relax, give it time and you might be surprised how much a few drinks can help
Perhaps try the nDac/555ps for a few days then siwtch the nDac out for the NDX... give that a few days and then put the whole lot together and see where you are at.
Posted on: 29 March 2011 by AMA
Mattia, you have to listen for nDAC with and without XPS for yourself. The OP had some setup problems which took him to the wrong conclusions -- which he confirmed in later posts.
If you pay me a visit I can show what happens if you put Burndy on powercord
I always keep cable dressing in immaculate condition -- and this is very important, no matter either with or without external PS. I have large spacing between the shelves on two racks and a lot of space behind the rack. The grounding is very important so I use a proper power box for powerlines.
Adding XPS on nDAC is not subtle, it takes nDAC to the top-class source. I'm sure PS555 is more so. Naim is not unique in using external PS -- check MSB DAC for example which is regarded as one of the best sources on the market. Most of the top level gears with built-in PS had already built-in the high quality PS which is both BIG and COSTLY, takes >50% of the box and >50% of the price.
Building the gears with built-in smallish PS and then upgrade them with external PS is nothing more but the Naim commercial policy. Technically Naim can design all their gears without PS and suggest PS555 for all of them. You may guess this will shrink the Naim sales market by miles.
Posted on: 29 March 2011 by Salmon Dave
Sorry matpip, the 555PS makes an instant and substantial upgrade, in my case to the nDAC. If it's not doing it on a NDX, then something is wrong. Simple as.
No - logically it just means that the small-case, small transformer DAC is better upgraded with the external power supply than is the large-case, large-transformer NDX.
I think Mr Senna has done us all a great service with his exhaustive test, one of the most honest I've ever read on a hifi forum. A breath of fresh air from the usual 'I bought a power supply because it should be better therefore it must be' hot air.
Now what did I do with that Supercap...
Posted on: 29 March 2011 by lhau
I'm saying a/b test because human gets confused easily when being bombarded with information and forced to make a choice. I am recently doing an ultimate a/b test, which was trying to pick a Maldives resort for my holiday on brochure and Internet. Well, there are certainly different classes of them, at first I couldn't perceive the difference, then the difference between them seems clearer, and then my brain is trying to "equalize" as it's generalizing the information. Shortly into the fifth or sixth resort, my mind became mixed up and cannot even discern the factual information like price facilities etc. As I was forcing to make a choice when I go back to the options again on Internet, the same information gave me different perception of the resorts again, and my choice was substantially different from what I thought I would picking the first round. Sorry if this story sounds irrelevant here, but the point I want to make is, if you switch too much too fast, your brains ability to discern even factual information is loss. It is even harder for hifi sound, just don't try it.
Posted on: 29 March 2011 by gav111n
At the Bristol show naim was using a 555PS on the NDX and AFAIK they have done the same at other public outings. There’s a reason for this and I don’t think it’s to sell unnecessary PSUs, I think it’s to make the NDX sing.
I think this exercise highlights how hard it can be to conclusively test even one new component. In order to try out an NDX you have to disconnect, re-position and then reconnect cables, the act of which in itself can bring changes to the system not related to the NDX (see also Simon-from-Suffolk’s thread about burndy wiggling).
I get a bit confused though, was it the case that in trying to accommodate the NDX, the Burndy/HL was pushed out of optimum? Or was it the case that testing the NDX revealed a cable optimisation problem that had been present for a long time? I can’t see it being the former as you would surely have heard straight away that the familiar nDAC/555PS sound qualities had gone awry. So if it’s the latter then this exercise has given a brilliant free upgrade. Maybe the message is to strip everything back and re-assemble, paying particular attention to cable dressing, then just enjoy the ‘new’ optimised system as it is for a while.
Gav
Posted on: 29 March 2011 by matpip
AMA, my provocative post was only a cheap way to get invited at your place!!
I know external PSs bring great improvement, I have an hicap on my SN and it is wonderful!
I'm just saying that many people, as myself probably, are happy to own nice gear and to listen music in a decent way, without caring too much about cable dressing, stack, speaker positioning and so on...for these kind of people, maybe one-box solutions (as linn) are probably more suitable.
On the other side, for audiophiles constantly looking for sound improvement, a one box solution is probably very frustrating!! come on, here we are talking about NDX+PS555+DAC+PS555, a 4 box solution (plus powerlines and DC1 and hiline), just for the source!
Posted on: 29 March 2011 by Asenna04
Hi all,
Thanks for your responses. Unfortunately I have not had time to run the tests again, but there have been good feedback from your responses.
Let me clarify that I do believe the PSU made a big difference. That is what I experiencec when I added first the XPS to my CDX2 and then to nDAC and then the 555PS to nDAC. There was a big difference. That is why I was shocked with my findings in Test 5 and 6.
ihau & goat,
I take your view that doing an a/b test like this will not show the differences. What the tests made me think is if there are any big differences by adding PSUs or between the NDX and nDAC. Surely it should be easier to stop the differences between 2 pictures if you have them side by side rather then view one for a few minutes then put it down facing down and wait for a minute and then pick up the second picture. But I respect your view that there could be mind tricks when doing the test like that.
Salmon Dave,
Your point about the nDAC having a smaller PSU as an explanation is not valid since I could not hear the difference in both Test 5 and 6. If that was valid, then surely the NDX/555PS would sound better then nDAC on its own with a smaller PSU. I posted my findings as I found them to get views form other people and also to see if someone can replicate the a/b switching tests as I did and try and see if they can hear any difference.
AllenB,
Yes, I admit my findings are strange. That is why I think I should listern to the NDX/555PS for a while and get used to its sound and then swap to nDAC/555PS. And that is what I am doing. But at the back of my mind I still have that doubt that if this approach will show the small difference there is between the two. Because, for the reasons given above, the a/b switch should show the difference since there is no time delay (and hence memory) when you switch. Now you know why I am confused.
bukakabo,
I don't think there is anything wrong with S400s. They are very revealing speakers. They were all over the place (up and down) when warming up, but now they are great. The fixing of the Burndy issue has shown even more how great they are since that was causing a big compromise.
AMA,
Your quote:
"I always keep cable dressing in immaculate condition -- and this is very important, no matter either with or without external PS. I have large spacing between the shelves on two racks and a lot of space behind the rack. The grounding is very important so I use a proper power box for powerlines."
I agree that I did not realise the importance of cable dressing until these test pointed to the fact that the power through the Burndy into the nDAC was compromised. I plan to completely strip the system and build it up again giving special care to cable dressing. I do have very little space behind the Fraim and the power sockets are right at the back there. But I think I can improve. Are there any good tips somewhere on how to optimise cables? OK the power cables should be kept well away from signal and Burndy, but what about speaker cables and the conenction between the preamp and power amp? Exactly how far apart should they be? Does it compromise the sound alot if they touch the wall/Fraim/Carpet?
Gav,
Your quote:
"I get a bit confused though, was it the case that in trying to accommodate the NDX, the Burndy/HL was pushed out of optimum? Or was it the case that testing the NDX revealed a cable optimisation problem that had been present for a long time? I can’t see it being the former as you would surely have heard straight away that the familiar nDAC/555PS sound qualities had gone awry. So if it’s the latter then this exercise has given a brilliant free upgrade. Maybe the message is to strip everything back and re-assemble, paying particular attention to cable dressing, then just enjoy the ‘new’ optimised system as it is for a while."
Its was the latter. It was indeed a free upgrade. I have never heard the nDAC/555PS sounding this good. And here was me waiting for the S400 to warm up
All,
Please continue to post your findings and I would really appreciate if someone can do the a/b switching tests. I will keep you posted on my findings.
ASenna04
Hi, Mattia
Come in any time -- my system is always hot and wine is always cold
The multiple-box source is not a big surprise in the world of no-compromise audio.
For example, dCS Scarlatii is 3 box solution (sans transport), GTE Trinity is 3-box solution -- and both of them need a streamer in front -- which is at minimum another box to count.
Or else you can buy a KDS and enjoy the single-box music
There are loads of cable dressing tips. I certainly can't achieve optimum on all cables so I do the best I can. For example, one of my NAP300 burndys rests on the carpet, also one of the preamp-to-poweramp cables is resting very snuggly against the fraim - what can you do!
My experience so far tells me that the HiLine is the most critical. It has been purpose built with mechanical de-coupling features. Looking back, I have had all sorts of inconsistent sound issues that I now attribute to the HL. Make sure the plastic tail rings aren't bust and as a priority get the HL free hanging and work everything else around that.
Gav
My preamp-poweramp cable is coiled on the rack -- no idea how can this be improved.
The powerlines are uncoiled and travel away form each other and the interconnects.
They don't touch the ground and each other -- and lay on the rack.
The other cables fly in the air without touching rack, ground or each other.
Including Hiline (which is quite rigid BTW) .
Yes, it's possible. Needs time and diligence.
End of.
...if you want to moan about Naim's PSU upgrade 'gravy train'.
Might be the 'end of' my 25 year ownership of Naim if that's the general level of reply.
I appreciate PSU upgrades as much as the next person when they clearly work. My point was that someone had bothered to do an exhaustive test and come up with some surprising results - one of which appeared to be that the expected PSU hierarchy wasn't quite as expected. There've been a few instances when I've preferred bare units to those with PSUs, and many others have agreed with me. Doesn't mean it's a universal truth.
As I haven't heard the unit (like yourself), I'm keeping an open mind.
Posted on: 29 March 2011 by Mr Underhill
Actually Allen I think you should be able to make your points without being personal; does nothing to maintain the convivial feel of the forum.
M
Posted on: 29 March 2011 by aysil
Dear ASenna04,
Thank you for sharing your results with us.
Some of your findings are not surprising to me at all. In fact, I also don't hear any tremendous difference between NDX and nDAC. There is just a distinct difference in character which I want to describe in another post.
As to your method, like many other people replying to your post, I also don't believe that a/b switching is a good way to compare components. Especially for minor differences, it is not suitable because the brain adapts to changes very quickly back and forth and it starts to become confusing. Listen to full tracks at least. In fact, if a component is stimulating you to listen to the end of a track is a very important test criteria. Years ago, I had a difficulty with the speakers I had at that time, but I did not know why. It sounded almost perfect according to all the generic "hi-fi criteria"; but I had discovered I was never listening until the end of CDs any more since I had got those speakers. One day, I read one of the drivers had a resonant frequency which may induce listening fatigue by some people. This was reason enough to get rid of them right away. Apart from such technical issues related to fatigue, the criteria of tendency to listen to the end of track (or cd) is about how much a device is capable of mediating to you the "soul" of the music.
I tend to suspect if the main problem with your tests is your source components. None of the devices you are comparing are IMO source components, they are intermediaries. According to my ongoing experimentations, the source of digital data (in your case the memory stick) has a TREMENDOUS influence on SQ. This may be contrary to some common assumptions. I hope to finish preparing a comprehensive post on this topic until the end of this week. I suggest you to question if your memory stick or Squeezebox are capable of bringing about the full potential of the nDAC or NDX. This is just a question, not a judgement, but a valid question I think. You could, I believe, experiment more on that aspect instead.
PS.  When I look at your source components, I want to question why you need NDX? NDX is used to its full potential only when used as UPnP client. Is Squeezebox a UPnP server? I am not familiar with it, but I guess not. (Edit: oh, I forgot, of course, you must have a computer in your network, which is surely a server by itself. So, I take back this PS section.)
Posted on: 29 March 2011 by Richard Dane
Asenna,
you need to be very careful doing a test like number 5 or 6.  Multiple earth references and the high likelihood of earth loops will basically cause a massive levelling of the playing field unless you are very careful - essentially making the sources sound very similar and below their potential.  To do this comparison in a more meaningful way - and thus avoiding the possibility of earth loops - you should only have on item connected into the pre-amp at any one time.  Try it again this way and see how you go.
Not surprised about your results once you had sorted the Burndy - getting this right - dressing, avoiding stressing etc.. makes a big difference.  Weird, but true.
Posted on: 30 March 2011 by Peter_RN
OK, this is Naim's forum, so this should be a fair question.
Putting all cost issues aside (because the 555PS is damn expensive), who would say no to a 555PS (or even a XPS2) in their system? For those who own one of those units, who would be willing to let it go from their system?
Apologies to the OP if this is detracting from the thread, but the PS has perhaps skewed the tests run, which has been acknowledged and are now being re-run. We look forward to reading the outcome.
Is that convivial enough?
Hello Allen
I usually avoid getting involved in this kind of discussion as I feel my knowledge is too restricted to my own system to be of use to others. I avoid visiting a dealer until our system no longer enables us to use it, as we would like; i.e. when CD had virtually replaced vinyl and now streaming.
However, in answer to the question you pose, there is no possibility of us ever removing either the Hi-Cap or XPS2 from our system.
Whilst I feel that on those occasions we have auditioned a new piece of kit it has been very good and acceptable in its own right, it has always improved with the addition of a PS. I see that as beneficial to the purchaser myself, it adds choice. The fact that a PS can be used on a variety of components is a valuable extra to their worth IMO.
Peter
