iRadio behaving strangely
Posted by: Dave***t on 24 November 2014
Something afoot at Naim's end, or is my UQ playing silly buggers?
Yep,me too.....
Same here..
Yup, its all broke !!!!
I was changing stations, RP to Naim & it all disappeared, so I thought it was me dun it wrong again. After some investigating I found it was not only Naims Choice, all iRadio had the little wheel spin thing
I zapped & reinstalled the app, rebooted the NDX, still all wheel spinning
Then it started to come back, it was slow loading stations, but all are now loaded OK except Naims Choice
broke here 2 ![]()
Naim's Choice empty still but all other options OK. RPs a bugger to find via the menu!
+1
All stations are gone and I have to reboot the NDS. This has happened three times during the last two days
Will check
Naims Choice is back, but its only the station listing from some time back, the new BBC AAC links are gone.
Also when I hit a station, the banner across the bottom of the screen disappears & to get this back you have to delete & reinstall the app
I'm gonna copy this thread to Naim.
All ok my end, will check with others
Yes it's being looked at with our supplier, will keep you posted sorry for the delay until normal service resumes
This may be unrelated, but a few days ago I noticed that in Naim's Choice, Radio Paradise 320k appeared 3 times on the list, once as RP Naim exclusive (or something like that) and twice as just RP320k. Then, a couple of days later, it was only there twice. Today, it's only there once, and some other channels are missing, including the Naim Radio ones.
Some other odd things I've just noticed: the RP 320k can maintain 100% buffer, but the 192k version can't. Neither can Radio 3 Hidef (test). RAI Auditorium is listed but won't play. AVRO is listed as 256k, but when you play it, it comes up as 64k. This all seems a bit odd!
RAI Auditorium has been useless for quite some time. As you may probably know, if you find AVRO K not through Naim Choice but via location it should stream 256k. Yes, it is strange. There can be something wrong with the service provided by vTuner.
When Naim's Choice was working I found that the Naim Exclusive version of RP occasionally suffered from stuttering whereas the other 320k AAC version that appeared in Naim's Choice (when?) played perfectly - worth trying.
