Muso does not like the BBC
Posted by: Acred on 24 November 2014
I am unable to get Radio 2 or Radio 4 extra to play from my saved presets. They are in the first and second slots. I can select other saved stations from my list without a problem. This problem started over the weekend. I've done several factory resets and deleted and reloaded the Naim App.
When I've finished reloading a number of favourite stations I am able to select Radio 2 or 4extra from the preset list without a problem. Put it in standby and leave for a while ie overnight I'm unable to get either of these BBC stations to activate.
Today when selecting either of these stations the restoring history alternates quite rapidly showing 0%, 25%, 0%, 25%. If it doesn't do that it says 'connecting' and just hangs. I can however select these stations from the Naim's choice tab. I've tried resaving them but the same problem occurs.
This seams to have happened after I used an Ethernet cable which I've decided to remove and go back to wireless. But as Ive said since removing the cable I've done a few factory resets trying to stabilise the presets and the problem only appears to be with the two BBC stations I've saved.
Has anyone else had this problem and been able to fix? I've run out of ideas.
