Audio Control via iPhone/iPad with NDX & Supernait 2
Posted by: LaurieHogan on 24 November 2014
Looking for some advice on how to get the volume feature to come through on the naim app via iPhone/iPad - I've linked the Remote in between the NDX & Supernait with no win.
Also checked the manual to try and give some advice but couldn't really see much.
Can anyone tell me where I'm going wrong please ?
Laurie
Posted on: 24 November 2014 by LeeTom
You must also turn on System Automation on the NDX. Using the front panel and remote, go to settings -> system automation.
Posted on: 24 November 2014 by Hook
Originally Posted by LaurieHogan:
...I've linked the Remote in between the NDX & Supernait with no win.
Laurie
Hi Laurie -
NDX remote out (one of 2) to SN remote in?
Hook
Posted on: 24 November 2014 by LaurieHogan
Hi LeeTom
I've put that on. Anything specific i need to go with?
Also I noticed that there is the option of a few different 3.5mm entry points on i think the NDX - should it be Remote in to Remote in i take it? (that's what i've got set up at the moment)
Laurie
Posted on: 26 November 2014 by sjbabbey
Hi Laurie,
As Hook has posted, you need to link from the NDX remote OUT to the SN remote IN and enable the preamp option in the NDX System Automation settings.
