Artwork and Asset
Posted by: JSH on 26 November 2014
I use Asset and Minim.  With Minim I (generally) get the artwork showing in the top level files and I can browse by album cover.  With Asset, I only get the standard file icon at browser level but when I play a piece the artwork then shows
The covers are are jpegs or pngs and are stored with the name "cover" or " folder" as I believe this is all Minim reads
Any help would be appreciated
Posted on: 26 November 2014 by sjbabbey
Check to see that you have got the Upstream Artwork option enabled in Asset's configuration settings.
