Things I wish my UnitiServe would do
Posted by: nudgerwilliams on 02 December 2014
As we've just had a firmware update, now is obviously the perfect time to start the wish list. Hope Pnil and TJ are watching. Have tried to capture the things others have mentioned.
1. Backup routine to include Downloads folder
2. Ability to edit metadata in Downloads folder (via nServe ideally)
3. A 24 bit / 48khz transcode setting. This is the max resolution that multi room works at and I want to use that as a default setting so whatever I am playing will work with multi room. At the moment I have to use 16/44.1
4. Ability to change transcode options on nServe app
5. Backup routine to include playlists (I don't think it does currently).
Any others people have?
