Updating HDX to v1.7b
Posted by: sktn77a on 02 December 2014
Anybody know if I can burn the downloaded ISO to a CDRW as opposed to a CDR?
Posted on: 02 December 2014 by Bart
Should be just fine.
Posted on: 03 December 2014 by sktn77a
Yes, in theory, it should be - the HDX is spec'd for CDRWs.  But the format of CDRW is different to CDR and I don't want to brick my HDX with an ISO that it may not completely recognize when loading firmware.  Has anybody used a CDRW to update the HFX?
Posted on: 03 December 2014 by ChrisH
I thought about it but opted for a CDR in the end, just in case.
A bit wasteful I know...
Posted on: 03 December 2014 by Claus-Thoegersen
With a new version of firmware out about every 24 months maybe a bit less, I find it better to use a fewcdr disks to be sure. Actually I do not  own that many cdrw disks anyway.
Posted on: 03 December 2014 by Richard D
In the accompanying "readme" notes for the upgrade, Naim advise against using CDRWs
Posted on: 03 December 2014 by garyi
Even the utterly rip off maplin charge like a fiver for 50 cdrs.
Yep, just scoured the accompanying installation guide and, sure enough, it advises against CDRWs.  Would probably work fine but I guess if it's an old CDRW with loads of writes and erases, it could bung up the works.  Dang, another 10 cents down the crapper!
