Uniti Updates
Posted by: pzblues on 10 December 2014
Hi everybody, i recently purchased a pre-owned naim uniti (the original one) had a bit of a look around the internet and noticed that there are software updates available, my question is, do i need to run/install all of these updates or can i just go straight to the latest one which i believe is 3.9
Many thanks
Posted on: 10 December 2014 by Daveas
Whenever there's an update the instructions usually say something like --  ensure you are using the most recent version of firmware/software before upgrading to the newer version--. So I suspect you'll have to go through them all in chronological order.
Have a look on the Naim Website/Customer Support/Product Updates if you haven't already been there.
Posted on: 10 December 2014 by pzblues
Hi and thanks for the reply, the instructions provided don't mention anything regarding current versions etc, i will check naim support once again but have found it to be quite vague on the subject to be honest, i was rather hoping that somebody here had already been there and done it.
Posted on: 10 December 2014 by hungryhalibut
It's my understanding that you can go straight to the latest version, which is 3.22. There will be another new version very soon, which will provide additional functionality, so you can either wait for that, or practice with 3.22 and do it again shortly.
Posted on: 10 December 2014 by badlyread
HH is correct. Might be worth a little wait for the new one.
Neil
Posted on: 10 December 2014 by LeeTom
You can just download the latest 3.22 version and install once.
Thanks everyone, i have just had a look and it seems version 3.22 is for the Uniti 2, the latest version for the original uniti as far as i can see is 3.17, is this correct?
Posted on: 10 December 2014 by Mike-B
3.22 is the latest
There is a new series coming in the near future,  so might be an idea to wait for that.  You might need to install 3.22 before the new series can be installed.  Its up to you,  but considering there isn't much diff between 3.17 & 3.22,  I would wait.
Ok and thanks for that, so when i go to the naim updates page and version 3.22 is aligned with 'uniti 2' and not 'uniti' i can ignore that and install on my orig uniti, is this right?
I suggest you drop Naim an email, or call them, just to check. Better safe than sorry.
Posted on: 10 December 2014 by bartve
Which firmware version you can install depends on the hardware status of your Uniti. Since the introduction of the orginal Uniti there have been 2 hardware updates (if I am right).
The hardware status of your Uniti is reflected in the BC SW number which you can look up in your settings menu. On the Naim download page there are clear instructions with each firmware package, ie regarding the BC SW number ....
Posted on: 10 December 2014 by Bart
In my experience, Naim hardware will not let you "brick" a unit by installing firmware that is not right for it.
And in my experience, there ARE instances where you cannot jump all the way from A to B without installing intermediate updates.
I feel confident that you can install 3.17, and if I were you I would do so.  From there, if it will let you install 3.22 I would feel confident in doing so.  The installers "know" what unit you are connected to and will only install what works, in my experience.  But if you are worried, dropping an email to support will surely get you an answer.  My best advice is to email support.
agree call or e-mail Naim
But I think you will find all the streamers use the same firmware download package called "UnitiUpgrader"  (that works for all models) & it includes folders for all the streamer models & it selects & matches your model to the correct firmware.
Exactly!  The software magically knows what you're updating
Ahh excellent, ok will do 3.17 and then try 3.22
Many thanks
Posted on: 11 December 2014 by pzblues
Really appreciate all the response, now my laptop has a 15 pin connector, the uniti a 9 pin connector, would that be where i would connect to install updates? Or do i need a usb to 9 pin serial connector?
Many thanks
Posted on: 11 December 2014 by hungryhalibut
The socket on the uniti is an RS232. You need an RS232 to USB lead.
Posted on: 12 December 2014 by nudgerwilliams
Suggest you read Naim's update instructions as they have guidance on the right cable to get and the right software drivers.
It has usefule stuff like this in it:
Com port type List
NaimUniti, UnitiQute, NDX
Requires 9 pin to 9 pin RS232 serial cable (or USB to Serial converter - ones with FTDI or Prolific drivers are suggested. An example of which is available here:
For most up to date FTDI drivers, follow the below link:
http://www.ftdichip.com/Drivers/VCP.htm
For most up to date Prolific drivers, follow the below link:
http://prolificusa.com/pl-2303hx-drivers/
Here is the link to where the update instructions are:
https://www.naimaudio.com/updates
Posted on: 18 December 2014 by pzblues
Thanks for all the advice, i decided to give it a go, everything went as planned until at 10% the upgrade stopped, i pressed retry several times, nothing, i then pressed abort but was warned that the unit would be unusable if i were to continue, my head is now in bits! What can i do?
Posted on: 18 December 2014 by ChrisH
Hi pzblues,
I would suggest to call or e mail Naim Support.
I'm sure the will be able to advise.
Hi, tried that and really wasn't much help, told me to warm it up and try again! My uniti is now stuck in upgrade mode, does anyone know how how i may be able to recover this??
Posted on: 18 December 2014 by Bart
In MY case, the 'abort warning' was over-zealous.  Aborting did not renter the unit unusable.  Given that your unit is not usable in its present state anyway, I'd abort and try again.  But that's me; please do what you feel comfortable with!
Cheers, took your advice, persevered and got there, phew! Now i have another problem i hope you can help with, i was using the serviio console to stream my music files from my laptop, worked pretty well too, however since the upgrade serviio does not appear as an option when i select pc (UPnP) What does appear is the name of my pc, when i click ok i get the message 'source error, unable to browse' Any ideas??
Posted on: 18 December 2014 by dayjay
I use Servio on my server to stream films (don't like it for music and use Asset) it is a right pain for closing itself down in which case its invisible until you reboot it and its running again
Excellent!  Enjoy your music once again!
