Spotify connect unitiqute2 not working
Posted by: BigRooster747 on 19 December 2014
read several posts about not recognizing model etc. Have downloaded version 4,1, coming from 3.23 unitiqute2 from august 2014. Guide won't show input com etc. What is the correct linkt to the usb driver for mac? It might be needed to get the update working. frustrating that is nowhere to be found.....
Posted on: 19 December 2014 by nudgerwilliams
In the download folder there is a pdf with the instructions and links to USB drivers in there.
I think that is what you are looking for - apols if not.
Posted on: 19 December 2014 by BigRooster747
not seeing it, totally bored with this. You mean the page under unitiqute2? There is no pdf and no link to usb drivers or some such...
I would have thought a good instruction to this upgrade but no.... quirky instructions.
On this page
https://www.naimaudio.com/updates
Scroll down to UnitiQute Version 4.1.  Click the Mac software update link.  It will download a zip file.  Open that up and there is a pdf.
Right at the top of page 2 are the links.
http://www.silabs.com/Support%...c_OSX_VCP_Driver.zip
To find most up to date drivers follow the below link:
http://www.silabs.com/products...ridgeVCPDrivers.aspx
Thanks Nudger (...) it works now. Overlooked the pfd in the download. Its visible in the finder, there you will find the link for the usb driver. Install that FIRST, restart en install the update. All is well now. Just unhooked the Squeezebox Touch....:-).
Good stuff.  Glad you got it sorted.  Will be a piece of cake next tim.
