BitPerfect/iTunes
Posted by: Jeff Anderson on 22 December 2014
Attempting to set-up and use BitPerfect with iTunes, all latest versions.
It always stops after the first track. Then if I start track two "manually" it plays the remainders of the files sometimes and sometimes stops again after second track.. I assume I have a tick box wrong or something similar. I have run "change directory" numerous times.
Did a search and found nothing on this track issue. Any help appreciated.
Jeff A
After loving BitPerfect for years, it has really lost the plot now. I simply can't get it to work reliably with the latest iTunes and OSX. I've given up until it gets patched.
Move to JRiver for Mac. Much more flexible. I've had some issues with it, but you get bit perfect out of the box, and don't need to deal with iTunes library craziness.
Thanks for the info, for now I will turn BitPerfect off.
Jeff A
I find the way iTunes manages my library to be exemplary. For me it is a real strength. I don't need any more flexibility. I can't fault it.
It's no good to me it used to make noises now it keeps stopping iTunes.
When searching, I saw your prior posts on noises. Your "stopping iTunes" sounds similar to what mine is doing. Thanks, Howard.
Jeff A
If you mean BitPerfect, then yes. It just locks iTunes up.
Been using Audirvana 1.5 for 19 months now, as @Wat says it just does the job without a fuss. and works with iTunes if you want it to (this is good for accessing Internet radio and previewing song from the iTunes Store and fir using the free Apple Remore app).
Compared with JRiver, this app has been designed for a Mac from the ground up, as opposed to porting a Windows programme to a Mac and doing so badly. I also found the SQ on JRiver to be wanting in comparison.
I'm also evaluating Audirvana 2.08 and, so far, I am extremely happy with the SQ over v1.5. Transferring my multi resolution files from my iTunes library was a breeze. The new look of Audurvana (which looks like iTunes) makes it easier to control via Mocha VNC on a iPad mini.
The roadmap for Audirvana looks rosy too, with a dedicated Remote app and intgegration of streaming services, starating wth Qobuz on the way.
Haven't done an in depth comparisons of Audirvana 2.08 against iTubes only yet, as I need the sample rate to be switched automatically. In this tegard, I would like to hear from folk who achieventh is without additional software.
Jude :-)
Jeff,
There is no need to use Bit P with iTunes now.
Its out dated tech.
If you get your settings right in iTunes since Yosemite and its upgrades there is no need for it.
You now have many more options to rip and download since Yosemite.
As Wat says above.
Audrey might be worth trying but there new album art cover flow isn't as good as iTunes.
Jeff,
Its out dated tech.
During playback, iTunes still won't switch my bit-rate in Audio Midi to play hi-res at full quality without BitPerfect running. With BP, the switching is automatic. What am I missing?
Jeff,
Its out dated tech.
Dont use audio midi.
Jeff,
Its out dated tech.
As I understand it, OSX and iTunes use it by default. What configuration do I need to change?
I would be interested to know to. How do you disable audio midi, or at least stop OSX using it?
This goes on and on.
The answer is to accept the standard [same as Rebook CD] that iTunes brings with it [without manual adjustment to a higher resolution standard].
Now you may say that Redbook is not good enough.
I would disagree. There is such a thing as too much resolution as recordings are designed for a certain degree off resolution in the replay chain.
Because microphone placement is always closer to the performance than the ears of the listener at a live concert, there is more non-musical detail picked up on the master than what is musically useful. thus a certain amount of lost resolution in the replay is actually a good thing.
Redbook is actually better at resolution than is necessary for all the vital musical information to be relayed ...
ATB from George
ATB from George
I don't disagree with you, George. But I also reserve the right to be paranoid that I'm missing something extra that I could get from the (relatively few) hi-res recordings that I have.
Fair enough, but until recordings are designed for High Resolutio replay, then I would forget your wish for more resolution.
And modern recordings are moving more toward the MP3 player than High Reolution.
Classical recording continues to improve towards perfection of timbre and balance, but the methods of microphone placement have not changed since the 1930s, and so replay need be so good but not better than good enough ...
Just two penneth' worth, from George
Jude :-)
FWIW, Audirvana (Audrey) 2 is staying. An easy decision on SQ terms alone. In non itunes mode the difference is clear to me and in my set up.
Libray management is also easy, IMO , if you are prepared to use a separate Mac or VNC program on an iPad.
I continue to use iTunes for Internet radio and Spotify free for discovery.
Jude ![]()
