Is it possible to turn the mu-so LED off?
Posted by: deepinsight on 27 December 2014
Hi,
Mu-so - love it. It's in the bedroom and the LED at the side is very bright in a dark room. Is it possible to turn this off?
Hi,
I also wish that you could complet off all LED. In the bedroom, it is distracting. Maybe this can be with an update enable?
Just stick something over it. It indicates connectivity with the WiFi so if you turn it off you'll have to reconnect via the app.
sorry, I did not understand what you mean.
Blutac is a wonderful thing.
WIFI can not be off? Because I like to use my ethernet cable.
There's a product called LightDims on Amazon. I used them on all our bedroom electronics to knock down the light output. Easy to peel and stick with a variety of shapes. Cheap too.
Ok. , I like this. I'll try. But I think WiFi should be off when you need it nciht.
Duct tape would work and match well enough that you would not see it. Also cheap.
If you have not tried it, we use a lot of duct tape in the US, to great effect.
Indeed Skip.
Duct tape and vise-grips should be considered indispensable in any handyman's tool box. I think either could be used effectively to dim the LED.
