Bluesound Node with Naim Muso
Posted by: ReneTS on 30 December 2014
Hello
Is it possible to add a Bluesound Node to the Muso, as I would really like to add local HD music files to my playlists. And as far as I know, this is not possible with any streaming services I know of.
Posted on: 30 December 2014 by LeeTom
Yes. Use an optical (toslink) cable to hook the two up. Then change the mu-so's input to optical and use the bluesound app to control what you're playing.
Posted on: 30 December 2014 by Bart
I would do an experiment to see (hear) whether you can tell the difference between true hi res playback and downsampled (such as an Airport Express will give you) before spending $450 on the Node.
But you may not be able to do the experiment without buying each!
Posted on: 30 December 2014 by ReneTS
Thanks for the answers. I can hear a difference with HD tracks, but if it is enough to spend a lot of money on a Node I dont really know yet But which DAC will be used if I connect a Node with Toslink?
Posted on: 30 December 2014 by Hook
Hi Rene -
If you connect the Node using Toslink, then you are delivering a digital audio stream, and using the mu-so's dac to covert to analog.
ATB.
Hook
