Spot iffy and Airport express
Posted by: Steve w on 02 January 2015
For all those like myself who are blessed with an early Unity and who don't relish paying for a board upgrade, I am happy to report that the addition of an Airport Express has enabled spotify streaming from the I pad / I phone . I don't find the sound quality bad at all!  Plus at £71,much cheaper than the Naim upgrade .
Posted on: 02 January 2015 by Jeff Anderson
Glad you have worked it out.  Enjoy it.
Jeff A
Posted on: 02 January 2015 by garyi
Its quite hard to understand what you are getting at here, this has been a solution since airport expresses have existed.
However its not spotify connect, the difference is significant so if other readers think its the same its not!
Posted on: 02 January 2015 by ChrisSU
I thought Spotify from an iPhone via Airport Express to my Superuniti sounded dreadful. At some stage I'll try the 99p for 3 months trial to see how much better it sounds now I've updated my SU, but I doubt I'll bother to keep up the subscription after the trial period.
Posted on: 02 January 2015 by Steve w
Appreciate that the airport express has been about for some time..however the lack of ability for early streamers to access Spotify without spending a large sum of money has only raised its head recently...was just trying to be helpful to others!
Posted on: 02 January 2015 by Simon-in-Suffolk
Steve, glad you are enjoying Spotfiy, but ever since the Spotfiy app has supported Airplay you have been able to do this into any Naim device with a Toslink input.. Certainly for a few years now.
Simon
