Radio Paradise 320
Posted by: Faux75 on 17 January 2015
Is anyone else having issues. For the past week I am getting dropouts every few minutes. It is fine on lower bit rate. My internet is running at a steady 8meg.
Posted on: 17 January 2015 by Mike-B
Its probably your internet - drop outs with 320k but OK at lower bit rates,
I am getting great service, 100% buffer with all the 320k stations,  internet is 14mb/s minimum normally 16 to 18 with once in a while 24mb/s  (thats via BT wires, not fibre optic)
Posted on: 17 January 2015 by Faux75
I'm with Sky and they have checked it and there doesn't seem to be any drops. It is pretty good with streaming video which will take up more band width.
I'm still betting on an internet problem.  but I'm no expert & maybe some of the experts can come in.
You say the lower bit rates are OK & the problem is with the 320k stream & its "for the past week"  .....  so whats changed ??
Maybe Sky have reset something - my BT Hub gets reset quiet regularly & they are always changing the IP address.
Have you tried resetting or rebooting the hub ???
Is the Uniti connection wired or wireless to the hub/router
Posted on: 17 January 2015 by Pev
I have a Superuniti and find that if I use the "Naim Exclusive" 320 RP feed I get dropouts. In the Naim's Choice menu there are a number of other RP feeds, one of which is also 320 - I find this is much more stable - worth a try.
Good point Pev,  I assumed it was the Naim's Choice stream we were taking about.
