How do I preset BBC radio stations on my muso?
Posted by: Wils on 18 January 2015
Hi,
How do I preset BBC radio stations on my muso.  It looks like you can only preset the stations found through the muso app. I'm guessing this is a user issue.
Thoughts welcomed.
Posted on: 18 January 2015 by ChrisH
Hi Wils,
I just had a look in the mu-so Product Manual - see page 11, Section 4.2.
It says iRadio preset store functions are only available via the Naim app.
But it does say that the first 5 in your presets list are available via the mu-so touch panel.
To store a station as a preset, select and start playing the station you wish to preset, and then touch the star icon - this will store it.
If you then go back to the Front Menu on the App you will see it in the presets list.
Hope this helps.
Posted on: 19 January 2015 by ChrisH
Ps. Richard D: probably should be moved to Streaming Audio section?
