Connecting MacBook Pro to Naim DAC
Posted by: Kevin Rodgers on 25 January 2015
I have a couple of beginners' questions about playing hidef files through Naim kit.
The first i hope will be trivial to the experts out there. i have a Apple MacBook pro Retina (late 2013 model). How should I connect this to my Naim DAC so that I can play hidef audio files? I undertsand that the Mac's digital audio output is through the headphone socket. Do I need a cable with male 3.5mm audio jack at one end and USB A at the other, or what? I have connected an iPod into the USB port at the front of the DAC and it worked fine.
The second question is slightly trickier. I put two albums (downloaded from 'HD tracks') onto a Kingston 16GB USB 2 stick. One is 16/44 FLAC, the other is 24/96 FLAC. When I plug the stick into the front of my (2010 vintage) HDX the n-Serve software can 'see' the first album but NOT the second. I have reformatted the stick and tried again - same result. Curiously, my Uniti (in a differnt part of the house) can see and play both. Any ideas of what is going on? Frankly, I'm not wild about using USB sticks but I tried it as an alternative to playing from my Mac.
Thanks in advance to anyone who can help with these questions.
