PDF instructions for 4.1 upgrade for ND5XS
Posted by: Karen on 25 January 2015
Will this PDF show up after I click on Download the Updater?
Posted on: 25 January 2015 by Bart
The download from Naim includes two files  -- the installer for the actual updater, and the .pdf instructions.
Posted on: 25 January 2015 by Karen
Thanks Bart. Will attempt Monday. Would not want to run into a problem today (Sunday). NAIM tech support not open and the 4th episode of Season 5 of "Downton Abbey" airs tonight.
Despite being in the States, I've seen the entire season already.  There are ways . . .
Upgrading with a Mac, or PC?  If a Mac, check this post regarding the usb driver install:
https://forums.naimaudio.com/to...31#45633858512111931
Posted on: 25 January 2015 by Mike-B
..............   and the correct USB (or RS232) drivers
I do have the correct USB cable and my computer is an iMac. Thanks. I will check out the link. Because the iMac and the ND5XS, which is hardwired to the internet. Because the computer and streamer are in two separate rooms, I will move the computer to the streamer. Will plug in the computer and then attach the mini USB cable. After the computer comes up, I will switch to wi-fi for the computer. As I understand the procedure, I can download the updater at the computer's current location (also hardwired). Once the updater appears, I can move the computer and then download the proper drivers. I like to have all of my ducks in a row since the closest Naim dealer to me in Coeur d'Alene is in Seattle.
