NDX new Firmware: no network
Posted by: Wolfgang on 27 January 2015
Hello,
every time, I switch on my NDX, it displays "no Network, press List". After pressing "List", it is connecting and everything is fine. before updating the NDX firmware, it was connecting to Network at once. Is there any solution?
Thank you
Volker
Posted on: 27 January 2015 by Mike-B
I have the same problem, not every time, maybe 1 in 3.
But I had the same problem before the 4.1 upgrade also,  so IMO its not caused by the new f/w.
I rarely power off anyhow,  but when I do I just make sure my NAS is fully on, then the switch before starting NDX.
Whatever the cause,  if it can be fixed in f/w, I fully expect it will be attended to in the next release.
