Broadband (Fibre)
Posted by: Mr Frog on 29 January 2015
Virgin National have ended support for copper cables to concentrate on their Fibre Optic Cable network - which unfortunately isn't availble in my area.
I have therefore, decided to switch to BT infinity 38mb FTTC - which should be superior to the existing 8mb copper line. At present I use a Draytek Vigor 120 Adsl modem linked to an Apple Time Capsule router. Once the switch to BT fibre takes place, the adsl modem will have to be replaced by something else (VDSL ?). I assume that the supplied BT Homehub 5 combined modem/router should be fine. I had planned to switch off its wifi function and use it purely as a modem, whilst retaining the Apple Time Capsule as the router - which has the NAS, Naim streamer etc attached via Ethernet.
Is this a sensible solution or should I just use the BT Homehub 5 for everything - both modem and router functions - without using the Apple device?
Alternatively, should I find another suitable modem (VDSL ?) instead of the BT supplied unit (perhaps a Draytek 130) and continue using the Apple router as before?
Any advice would be greatly appreciated ![]()
